by Nickibarlow2000
New Member
Can I use my phone in Dublin
Can I use my phone for texts calls and data in Dublin? And won't get charged?
Solution
Re: Can I use my phone in Dublin
You can but it will be at roaming rates as you will be outside the UK when in Ireland - see http://explore.ee.co.uk/roaming/ee/ireland .
If you're on Pay Monthly contract make sure you have roaming enabled on your a/c by texting ROAMING to 150 & follow its instructions.
Solution
