Highlighted
New Member
Can I use my phone abroad in New Zealand and how much extra will it cost me?
Highlighted
Solution
Re: Can I use my phone abroad in New Zealand and how much extra will it cost me?
Hi @hollylafford
It depends on your plan. If you have a max plan taken out after 10/05/17 then you can roam as at home.
General costs and add-ons can be found here.
You should also text ROAMING to 150 to ensure the service is activated.
Highlighted
Solution
Hi @hollylafford
Recent solutions
