by Kyle370
Can I use my my phone in italy
Can I use my EE contract in Italy with out getting charges
by Ace Contributor
Solution
Re: Can I use my my phone in italy
Hi @Kyle370
Welcome to the EE Community,
as Italy is a EU country you can use your inclusive allowance while travelling in Italy subject to 15GB data usage per month.
If your a Pay Monthly customer text ROAMING to 150 to make sure your account is enabled before you leave the UK.
Thanks,
David.
by Ace Contributor
Solution
Hi @Kyle370
Thanks,
David.
by Kyle370
Thank you David
Glad you got the help you needed from the community @Kyle370
Have an amazing time in Italy 🙂
