by sharynhackett
New Member
Can I use my monthly allowance in Lanzarote to make calls and texts and use data
by Brilliant Contributor
Solution
Re: Can I use my monthly allowance in Lanzarote to make calls and texts and use
Hi @sharynhackett Yes you can use them in Lanzarote there is a fair use age of 15gb for data if you have more than that in your plan.
Please Text Roaming to 150 before you leave to check you are all set up
Solution
Hi @sharynhackett.
Welcome to the community 🙂
I can see @Damienw1 has provided a brilliant answer for you, has this fully answered your query?
Remember to set up your My EE if you haven't done so already, just so you can check your allowances when you're abroad.
Let us know if you have any further questions, and have a great time in Lanzarote!
