by Jojo2610
Can I use my mobile in Cuba
Can I use my mobile in Cuba on pay as you go?
Solution
Re: Can I use my mobile in Cuba
@Jojo2610: Yes, for calls & texts, but not data, at standard unit rates given in https://explore.ee.co.uk/roaming/ee/cuba .
by Jojo2610
Can I use my phone in cuba
Can I use my PAYG in Cuba
Solution
by Ace Contributor
Re: Can I use my phone in cuba
@Jojo2610
You can use your Pay as you in Cuba but it will cost you a lot.
Have look at this http://explore.ee.co.uk/roaming/ee/cuba.
Many Thanks
by Profile closed
Not applicable
You can, however, it's very expensive and it's 2G only with no mobile data.  Call costs can be found here (£1.00 per text sent or £2.50 a minute for calls).
There's not much WiFi either and what there is is often very very slow.
EE Employee
Hi and welcome to the Community @Jojo2610
Please do pop over to our Roaming Topic before you go.
Whilst we do try to provide calling and texting coverage whilst in Cuba, we cannot guarantee this as it is all depending on the local infrastructure,.
We are unable to offer any mobile data.
There
Many thanks,
Lee
