by beastamon
New Member
Can I use my minutes and texts in Seattle
Can I use my minutes and data in the USA and are there extra roaming costs?
Solution
Re: Can I use my minutes and texts in Seattle
@beastamon  Are you a contract customer or a pay-as-you-go customer if on contract do you have a max plan if you’re not on the max plan then yes it will cost you as your allowance does not cover you in America.  Text RO AMERICA to 150 to see what your options are.
Solution
