by Diane_gfc
Can I use my internet as normal I Spain with no data roaming charges?
 Hello. I am currently on holiday in Spain does anyone know if I can use my normal data within my contract without incurring data roaming charges? Thank you
Re: Can I use my internet as normal I Spain with no data roaming charges?
As long as roaming is activated then yes you can use your plan as normal. Please see EE roaming guide.
Also be aware of the data usage :
If your domestic data allowance is greater than 15GB, you will be subject to a fair usage policy of 15GB whilst you are roaming in our Europe Zone: this means you can use a maximum of 15GB from your data allowance while roaming.
When the fair usage policy applies to you, once you have used up 15GB when roaming, we will notify you and you’ll have to buy a data add-on if you want to keep using data when roaming.
EE Employee
Hi @Diane_gfc and welcome to the community.
Please follow the advice given by @Northerner in regards to using your phone abroad.
Correct me if i'm wrong, but by your user name I would take it your a Gills fan?
Cheers
Lee
