by Ph0n3us3r123
New Member
Can I use my data when traveling in Poland?
Solution
Re: Can I use my data when traveling in Poland?
@Ph0n3us3r123 : Yes, it is part of EU. You may use your allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
