by Bluholgate
New Member
Can I use my data in Greece?
Can I use my 100GB data in Greece?
Solution
Re: Can I use my data in Greece?
Hello @Bluholgate
You can use your minutes, texts and up to 15GB of data 🙂
Before you go make sure you are set up to use your phone in Greece.
You can do this by texting ROAMING to 150, or you can log into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
Have a great time.
@Bluholgate  You can use your allowances in Greece but only up to 15GB per month.  Just text roaming to 150 before you leave the UK. You can do this now
Solution
Hello @Bluholgate
Have a great time.
