by Jennap0707
Can I use my data in Cyprus and do I need to change settings?
I've heard that you can now use you data anywhere but do I need to contact EE or change any settings before I go to stop me from getting charges?
by Brilliant Contributor
Re: Can I use my data in Cyprus and do I need to change settings?
 Hello @Jennap0707,
Welcome to the community,
Yes it is included, you can use your inclusive data there, you can always check by clicking help and then roaming charges and putting in the country to see what or if there are any charges.
Just make sure that international bar is lifted and roaming is enabled on your account, which you can do by ringing up EE or going into your account and checking there. If you have put a bar on premium numbers, then you will need to get that lifted, otherwise international calls are barred too.
Have a good holiday.
Just txt ROAMING to 150 and you will receive a message letting you know if your account is activated or not. If not then you need to contact EE CS on 150.
Also a word of warning, North Cyprus isn't included in the EU roaming countries so just be careful if you are near the border as you might connect to a Turkish mast.
by Jennap0707
Great thanks, I text the number and it looks like I'm all set! I am going to Paphos, not sure if this is near North Cyprus but I will have a look. Thanks again
You are welcome, glad to be of help, enjoy your holiday @Jennap0707.
