by Im33 Investigator
Can I use my data I'm malta
Hi can I use my data included in my monthly plan in Malta
by Profile closed
Not applicable
Solution
Re: Can I use my data I'm malta
Hello @Im33 it depends what plan you have. Currently only EE PAYM EXTRA & MAX plans include data roaming in the EU with all other plans needing a data roaming add on. However, from 15th June 2017 all customers will be able to use their UK allowances within the EU & EEA:
https://community.ee.co.uk/t5/Roaming/Free-EU-roaming-Who-s-covered-and-what-s-included/td-p/559046
http://shop.ee.co.uk/international/travelling-abroad
Here is a link to the EE roaming tool where you can check call charges and data roaming add ons if you are traveling before then:
http://explore.ee.co.uk/roaming/ee/malta
by Profile closed
Not applicable
Solution
Thanks for the great advice @Profile closed
Have a lovely time @Im33 I would also suggest making sure the device is set up to use in Malta by getting in touch with us 🙂
Thanks very much, Leanne 🙂
