by Smc1977
Can I use my 4g in eu
by Ace Contributor
Solution
Re: Can I use my 4g in eu
Yes, you can. Though please make sure you follow the guide in the link below to ensure that roaming is enabled.
https://ee.co.uk/help/help-new/roaming-and-international/using-your-device-abroad/do-i-need-to-activ...
W
by Ace Contributor
Solution
W
Recent solutions
