by Aminar15
New Member
Can I use my 4G when I travel to Istanbul?
Re: Can I use my 4G when I travel to Istanbul?
@Aminar15   Unfortunately not as Turkey is not in the EU so you can not use your allowances while there.
text RO TURKEY to 150 to see what your options are.
also text ROAMING TO 150 before you leave the UK.  You can do this now.
@Aminar15 : You'll be using whatever 'G' the local networks give you.
Turkey is not in the EU & so you can't use your normal allowances there. You will need to buy a roaming data add-on as set out in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/turkey... .
