by oscar1957
New Member
Can I use my 4G data purchased in Uk in Australia?
Can I use my 4G data purchased in UK in Australia
Solution
Re: Can I use my 4G data purchased in Uk in Australia?
Morning @oscar1957
Just to add to the great advice from @XRaySpeX, before you go text ROAMING to 150 to make sure you're all set up to use your phone in Australia.
If you have a 4G Max Plan started after 10 May 2017 you will be able to use your allowance in Australia.
You can check this within your My EE account > Plans & Add-ons.
Hope you have an amazing time 🙂
@oscar1957: Only if you are on an EE Max Plan. Otherwise you will have to buy a roaming data add-on. For roaming charges there s https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/austra...
Solution
Morning @oscar1957
