by hollbars Investigator
Can I use data roaming on max plan in America?
Re: Can I use data roaming on max plan in America?
@hollbars: Yes, just text ROAMING to 150 before you leave the UK to check that you have roaming enabled on your account.
EE Community Team
Hi @hollbars,
Did you get a chance to activate your roaming as @XRaySpeX advised via our text service?
You can also check the settings on your handset are correct before you go.
Safe travels 🙂
Alex
