by Hellsmonkey
New Member
Can I temporarily upgrade to a maxx plan before I go on holiday
by Profile closed
Not applicable
Re: Can I temporarily upgrade to a maxx plan before I go on holiday
You can upgrade to a higher cost plan but do bear in mind that once you upgrade your plan, you then cannot downgrade it until you reach the end of your full contract term.
