by Penelope2
Can I take photos abroad without incurring additional charges?
Which add-on do I need to use my phone to take photos abroad?
by Penelope2
Re: Can I take photos abroad without incurring additional charges?
Thanks Mark. I was cruising from Japan to Alaska!
Sent from my iPad
by Brilliant Contributor
Taking photos doesn't cost you anything. Using data/texts/calls does.
@Penelope2  if you use location services for your photos it will use a small amount of data.  If you going to somewhere in the EU it'll just use your data as normal as you can now use your calls/texts/data as if you was in the UK.
You can take them. They are a function of your handset. They will only be charged when you start sending them to others as Picture Msgs,
