Highlighted
by Investigator
Calls in USA
I've arrived in the US and have no network coverage. I've tried turning data roaming on but nothing shows up. Network selection is turned on to automatic.
I didn't text Roaming to 150 before I came and now, there seems to be no way to do so, without a mobile signal! Can you help?
6 REPLIES 6
Highlighted
Re: Calls in USA
If you are on contract, try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Highlighted
Re: Calls in USA
Hi @chriselcombe
Thanks for posting 🙂
Can you try the steps @XRaySpeX has provided and let us know if this works for you?
Hope you are having a great time 🙂
Highlighted
by Investigator
Re: Calls in USA
Hi Leanne,
I tried these steps but roaming and calling from abroad were already ticked as active. Can you suggest anything else?
Highlighted
Re: Calls in USA
Hi @chriselcombe
Thanks for trying this for me.
Can you try these steps below;
  • Try a re-start on your device
  • iPhone – Settings > Mobile Data > Network Selection > Turn off Automatic
  •  Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  •  Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know how this goes 🙂
Highlighted
by Investigator
Re: Calls in USA
Hi Leanne
I woke up this morning with network, before I needed to try your suggestion. Maybe it just took 24 hours for it to be activated? Anyway, hopefully that will be it sorted now. Thanks for your help.
Highlighted
Re: Calls in USA
Great news @chriselcombe
Thanks for coming back and letting me know 🙂
Have a brilliant time.
