by Marsellas187 Investigator
Calling from usa
Hi, I'm currently in the USA on a max plan. I've been assigned AT&T as a network but it won't let me call UK numbers. Any ideas?
The  tells me automated message to call 611 for customer service but when I do it tells me to contact my service provider.
6 REPLIES 6
Re: Calling from usa
@Marsellas187  Login to your online EE account and enable call abroad and premium rate numbers then restart the device.
Hi @Marsellas187
Welcome to the community. I hope you are having a fantastic time in the USA so far. 😄
It's really important to check the settings in your My EE account that @Chris_B mentioned above. Any changes in there can take up to 24 hours to go through fully.
If you're still having problems, please try manually connecting to a different network, to see if you get the same problem.
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Hi Chris, I've tried switching the calls abroad/premium block off several times now. Waited 24hrs but then when it doesn't change I log back in and blocked is switched back on.
Also there are no other networks that will connect here. I would call EE but that is the problem.
Any ideas?
OK thanks, @Marsellas187?
Can you receive calls?
Yes I can receive calls and text but can't return either. Data works. I was also able to make a local call to a US number ok.
I've sent you a private message to get some information from you.
Please take a look and get back to me.
