by AmalUAE Investigator
Calling from the UAE to the UK
Can I use my EE mobile from Dubai to call the UK?
Re: Calling from the UAE to the UK
@AmalUAE  Yes you can and you’ll be charged according to the roaming rates.  If you text RO United Arab emirates To 150 you’ll get this reply.
Our Travel Data Pass gives you a massive 500MB of data for a fixed £5 a day. Opt in once and you'll only be charged on the days you use data in United Arab emirates while you're away. Reply TRAVEL to opt in now or see add-on.ee.co.uk/traveldata for full details.
Calls made in United Arab emirates are charged at £1.50/min & £1.50/min to receive. Texts cost 50p and picture messages 50p each. Visit ee.co.uk/roaming for more info.
To check if your phone is set up for to use abroad reply ROAMING.
Dont forget to text ROAMING to 150 to enable roaming on your account.  You can do this now if you wish.
EE Employee
Hi @AmalUAE and welcome to the community.
Hope the information provided by @Chris_B has helped.
Many thanks,
Lee
Thanks Chris for your reply. Just to clarify: I will be in the UAE for 6 months, so before I leave. I want to text to the Uk whilst I am in the Dubai and receive texts from the UK
What would be the fees for this from EE side?
Amal
