by Jessicagart Investigator
Call uk from abroad
Hi, I am in Spain and my plan includes calls to EU and back to UK. I can call spanish numbers but it doesn't work when I try to call a UK number, and obviously O can't contact EE as it's a UK number.
I really need this sorted! Can someone help?
by Brilliant Contributor
Solution
Re: Call uk from abroad
Have you tried restarting the device.
@Lee_H @Karen_C @Leanne_T
Any ideas here. Roaming must be enabled as they can ring spanish numbers.
6 REPLIES 6
Are you dialing the numbers like 07 or 01
Or Dialing them like +447 or +441
It should be the later.
Thanks for the quick reply! I am diallingthe second way...
Sent from my iPhone
Solution
Hi @Jessicagart
Thanks for coming to see us in the community 🙂
Thank you for tagging us in @BrendonH and I will see if I can help.
@Jessicagart can you check for me whether Dial Assist is activated on your phone?
Go into Settings >>> Phone >>> Dial Assist
Please check whether the toggle is on for me?
Richard
I didn't think about it! Sorted!!
Thank you very much for your help!
Sent from my iPhone
Ah brilliant @Jessicagart
Super happy we could help you, enjoy Spain and come back and see us any time in community.
Richard
