by hamor16024
New Member
Call divert from US to UK number voicemail charges?
Hi currently in the US. Have diverted my calls to a UK number but have left my voicemail on. Will I be charged if anyone leaves me a message or even connects to voicemail & hangs up . Not sure as the number is diverted to the UK if they are included in normal package?
by Ace Contributor
Re: Call divert from US to UK number voicemail charges?
i would recommend you to to switch off voicemail when you're roaming in the US. As if anyone left you a voicemail will cost you at least £1.20 per minute.
Please see the roaming page for more info:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
W
Hello there @hamor16024
Just to make you aware you would be charged for diverting calls at the Roaming rate. See the Roaming Pages for charges.
Once you turn your phone on abroad it picks up the Roaming Network.
Thanks, Leanne.
