by Chris991
Call barring
I am on PAYG roaming in Cyprus.  All outgoing calls barred and I cannot change this, please help
[mod edit: please do not post personal information such as phone numbers on the public board. Thanks!]
by Chris991
Solution
Re: Call barring
Richard
thanks for your support.  I was in touch with EE who changed some setting and also added £1 as they thought my credit balance of zero may have had a bearing.  I was able to make outgoing calls for a while, then back to square one.  I saw that the automatically selected carrier was MTN.  I took auto carrier selection off and manually selected Cytamobile-Vodafone/EE and that seems to have done the trick.
Re: Call barring
Hi @Chris991
Thanks for coming here 🙂
Have you tried switching the phone on and off again?
Also, have you tried a manual network search?
How do I do a manual network search?
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
If you are close to the border with Northern Cyprus, please be careful not to accidently access a Turkish network.
Let me know how you get on.
Richard
by Chris991
Solution
Re: Call barring
Richard
Re: Call barring
Morning @Chris991
Glad you got this sorted 🙂
Have a great time.
