by davonnd Investigator
Call barring
  1. Hello I am in Santorini and can't use my phone to make or receive calls which is very frustrating. The posts on on this topic are not helpful as there is no solution. Is there something that EE can do about this since it does not affect other networks. I have tried several combinations to unlock the barring but nothing works. Pleaseeee I need help!!!! I have never had issues with EE before as they have been fantastic so this is my first.
Solution
Re: Call barring
If you log into your online account or use the "contact us" link at the top of this page then you can use live chat and ask them to activate roaming on your account.
It can take 24 hours to fully activate.
You should have checked this was activated before you left the UK.
Thanks,
Solution
Re: Call barring
Thanks,
by Lynz1 Investigator
Re: Call barring
Thank you for your advise....i had a live chat with agent Jamie and he updated my settings and now i can make calls ☺ happy days
Ta
Re: Call barring
Hi @Lynz1
Lovely to hear the good news, I'm sure @Northerner will be happy to see this.
Cheers
Richard
Re: Call barring
Thanks a lot. It works perfectly now. My main complaint is that there should be some sought of awareness about the activation. The ee community is brilliant though and thanks alot northerner and the ee live chat agent that activated the call barring for me. It was very swift.
Re: Call barring
Hi @davonnd,
I'm glad you were able to get the advice you needed in the community.
Enjoy the rest of your holiday! Smiley Happy
