by hayleyshingles Investigator
Call barring password
Hi, I am travelling abroad and unable to make calls to the UK! I am a pay as you go customer and just topped up with credit. I think it's because one of the call barring to home is green. However I need to enter a password and I did try 1111 after a couple of other attempts and it didn't work? Can ee help me if this is why I can't place calls and lift the barrino?  Thanks
by Ace Contributor
Re: Call barring password
HI,
@hayleyshingles
Are you using number in international format?
Use 00447 ***** or +00447****
But if you still not able to call then you need to call customer service on 07953 966 250 or you can use free phone number 0800-956-6000 where you can call from Skype.
To ask remove your call barring.
Many Thanks
Morning @hayleyshingles,
Have you managed to get this working?
Let us know how you are getting on 🙂
