by Simonk243 Investigator
Call, Text and data costs from non e.u. European country to u.k.
What are the costs for calls, text and data from a non e.u. European country to the u.k. specifically Montenegro if the costs vary. Looked on ee.co.uk but as usual impossible to find this sort of info.
Thanks.
Solution
Re: Call, Text and data costs from non e.u. European country to u.k.
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/monten...
7 REPLIES 7
Solution
Hi @Simonk243
Yes is very hard to search "roaming costs"
I searched for you just to ensure you here.
Hi there @Simonk243
Thanks for coming here.
If you type in the country you are visiting within the EE Roaming costs tool, you will be able to view the costs and add-on's available.
Full information can be found on our EE Roaming: Getting ready to use your phone abroad post.
Hope you have an amazing time 🙂
£1.80 a minute to make calls unbelievable ! I'm going to be staying a few miles from Croatia an e.u. country where I can use my calls and data allowance. I can understand charging customers outside their allowance or if not in the e.u. but not that much.
Can I make calls over Wi-Fi abroad or are these restricted?
by Brilliant Contributor
Sorry, no, as you will still be charged, but you can use something like Skype or Viber to make calls, so long as you make sure you have credit with them, you can also see how much it will cost you to make the calls using these sort of apps too.
Wifi calling is only available in the UK and with the right phone, but if you make a call that is chargeable then you would still have to pay. Not sure how you were thinking it would be cheaper over Wifi, it would still be the same, although with one of those apps, it would be cheaper, I am sure and can be made over WiFi.
If the person zou are calling has the same app as you and you make a call over Wifi, then it should be free, as that is chat, if that makes sense to you.
Yes sorry I meant using something like what's app calling on Wi-Fi if the hotel allows it on their Wi-Fi as it's an app and on Wi-Fi surely that would be free?
@Simonk243, Yes, that would be free and fine to use, just make sure that the person you intend to call also has what’s app.
