by wywh42 Contributor
Buying more data whilst roaming in France
How does this work as the app purchase extra data option says you can't use it unless on the ee network so that won't work in France i assume?
I logged in to my account & the only option was the data pass for outside of euope.
So how do you buy an extra GB or two if you are in France & almost used your allowance.
I am on a Monthly SIM only deal.
Solution
Re: Buying more data whilst roaming in France
You use your UK allowances in France. It's in the EU. So you just buy a normal UK data add-on. Just browse to http://add-on.ee.co.uk/purchase . It's within the EE network.
7 REPLIES 7
Solution
EE Employee
Hi @wywh42 and welcome to the community.
Please follow the wonderful advice given above by @XRaySpeX to assist.
Many thanks,
Lee
Thanks  but does that link work when on a French network not EE?
I understand how roaming works i just need confirmation that you can buy extra data when you are actually abroad roaming and also are the data charges the same price as if you were buying them in the uk.
Why did somebody else mark this as solved, isnt that my choice!!!
EE Employee
Hi @wywh42
The link will work anywhere you need to purchase data.
The charges are exactly the same as when you are in the UK.
The solution can be marked by anyone that see the solution to be correct and in this case @XRaySpeX is indeed correct.
Many thanks,
Lee
Ok thanks, will try this in a couple of weeks in France...
Hi all, i can confirm this works when in France. Just bought some more data very easily.
You do have to turn Wifi off otherwise the link is very fast & easy.
Thanks for the advice.
Thanks for the update @wywh42
Enjoy your time in France. Smiley Happy
