by Littlemissnutz
Being charged for calls from shared sim on anytime max 100gb plan
I have an anytime max plan 100gb with 2 sharer sims. The £13 ones. Currently in the USA and have noticed that EE has started charging for calls from one of the sims. Since 2017 we’ve been on a max plan and they’ve not charged for any calls on any line whilst in the USA. Main line was upgraded in September 2018. Have they changed this? And if so why was I not told during the upgrade that I’d Be charged to make calls from the USA on the shared sims?
by Ace Contributor
Re: Being charged for calls from shared sim on anytime max 100gb plan
Hi @Littlemissnutz
EE doesn't have a sharer sim any more.
Those must be additionals plan sims with EE essential plan and you will get charge if you are in the USA and make a call or receive with those sims.
