by jmalabre
Barring my phone & using Wi-Fi only
I am abroad & I want to stop making all calls and texts but use Wi-Fi only.
Phone prompts for a password .. anyone know the default barring code. I have an 18 month old Samsung S6.
Re: Barring my phone & using Wi-Fi only
What is the name of the code its asking for (puk/puk2) as it sounds like you already don't have access to cellular data.
If this is just the password then you will need to ask the owner.
To use the phone without cellular service just remove the sim.
Thanks,
by jmalabre
The error I get is when using the option is under Phone -> Settings -> More Settings -> Call barring -> Voice Calls -> International Calls
The phone asks me for a password but when I enter one it says "Failed to read data Call barring rejected".
I have searched all the web forums and used all the recommendef defaults like 0000 & 1111 & 2222 as well as other personal codes .. all of which fail to bar voice.
I would also like to do this barring for video calls and texts as well.
Hi @jmalabre
If you want to just use WiFi you can just take the SIM out as @Northerner has suggested.
Have you tried that?
Iv'e done that with my IPad and it worked a treat.
Cheers
Richard
by Ace Contributor
you can also go into airplane mode and turn wifi back on, and you won't be able to make or receive calls or use cellular data.
