by ShugC Contributor
Barred calls from the EU to U.K.
I am set up for calls from the EU to the UK, with EE, my texts an emails are working okay but I keep getting calls barred message. This is probably something simple any help appreciated. ShugC
Solution
Re: Barred calls from the EU to U.K.
Hi @ShugC,
Thanks for joining the EE Community.
It sounds like you have an international calling bar on your account.
I'll send you a private message with a link to chat with customer services online.
@ShugC  Just to check your are putting 44 instead of the 0 at the start of the number?
Solution
Hi @ShugC,
Chris thanks for getting back to me, have placed the +44 in front of the numbers and removed the 0s to no avail
James contacted EE techs through EE chat line and problem resolved by turning off automatic carrier network and selecting a different carrier from the list.  Switched phone off and back on again and it made calls to uk
many thanks
ShugC
EE Employee
