by Evsyb
Are there roaming charges in Europe
by Ace Contributor
Solution
Re: Are there roaming charges in Europe
Hi @Evsyb  you can use your allowance in EU with any extra cost.
You can use upto 15gb free data allowance.
by Ace Contributor
Solution
by Evsyb
