by MikeJ80 Contributor
Apple Watch in USA
Got a contract with EE on my Apple Watch. Can I use it over in the USA like back home or will I get charged etc?
Solution
Re: Apple Watch in USA
@MikeJ80  It’ll not work with it’s data allowance outside of the UK.  It’ll need to be connected to the iPhone all the time.
Solution
I don’t want to use the data on it. If I leave it on, will I get charged????
@MikeJ80   No because it will not get a signal to use data.  It will just use your iPhone data connection.
Thanks 👍🏻
