by Hayleyp91 Contributor
Any USA numbers that won’t be included in my plan?
Can anyone tell me if there’s any USA numbers that won’t be included in my plan? Don’t want to be caught off guard and be charged!
by Profile closed
Not applicable
Solution
Re: Any USA numbers that won’t be included in my plan?
Yes, as long as you have a Max plan, all standard US landline and mobile numbers (which you actually cannot tell the difference between as all US mobile numbers start with localised area codes) will be included in your plan whilst you are roaming.
@Hayleyp91 You'll be ok to call mobile number and landlines that are not chargeable.  @Profile closed might be able to give more information.
by Profile closed
Not applicable
Solution
