by Poppy7 Contributor
Abroad - phone charges - add ons
I am travelling to France on 11th June - 15th June. I have a SIM only monthly contract that I took out in 2015. Is it correct that I will only be charged 4.4p per min phone calls to Europe and 1.4p per text? If so then the £2 a day add on for unlimited calls and texts seems a bit odd? I would be grateful for any advice on this. Thanks
EE Employee
Solution
Re: Abroad - phone charges - add ons
Hi @Poppy7 and welcome to the community.
Please see our charges for roaming in France, the £2 per day is more beneficial if you are a heavy user of your phone.
Please do remember as of the 15th June, roaming regulations are changing, please see our guide on this.
Many thanks,
Lee
EE Employee
Solution
Many thanks,
Lee
Thank you for the quick reply, it looks as though I was correct about the charges so won't use the add on.
EE Employee
Hi @Poppy7
It's good as a buffer if you are not sure how much usage you are going to use in a particular day.
Many thanks,
Lee
