by midge69
4gee max
Hi, on a 4gee max plan with 30 gb data, how much data can use in usa.
by Profile closed
Not applicable
Solution
Re: 4gee max
Hello @midge69 you can use up to 15gb of your data allowance (fair usage limit) when roaming abroad:
http://shop.ee.co.uk/international/travelling-abroad
by Profile closed
Not applicable
Solution
Re: 4gee max
by midge69
Re: 4gee max
Cheers Tom222
by Profile closed
Not applicable
Re: 4gee max
You are welcome @midge69 come back to the community anytime if there is anything else you would like to know. 🙂
