by Brogster
4gee max plan since 2016. Can I use my minutes, data text in USA?
Hi There, I have a 4gee max plan. Contract commenced in September 2016. Is USA included in the roaming allowance for using text, data and minutes? I’m confused as it keeps referring to after may 2017?
any help greatly appreciated x
by Brogster
Re: 4gee max plan since 2016. Can I use my minutes, data text in USA?
Thank you so much for the speedy response
Sent from my iPhone
by Profile closed
Not applicable
No sorry, any Max plan purchased before May 10th 2017 won't include those 5 extra none-EU countries.
If it's a Max handset plan you currently have, then EE may be able to switch your current Max plan to a new Max plan which does include those countries.
Hi @Brogster,
Thanks for visiting the EE Community.
That's great advice from @Profile closed, please get in touch if you would like to change your plan.
