by Tarquin2 Contributor
4gee Max plan roaming in Balearic Islands?
Can 4gee Max plan roaming be used in the Balearic Islands? I know it can be used in Spain but is the same true of the Spanish islands?
EE Employee
Solution
Re: 4gee Max plan roaming in Balearic Islands?
Hi @Tarquin2 and welcome to the Community.
The Balearic Islands fall under Spain for our roaming rates, so yes the max plans will work.
Many thanks,
Lee
EE Employee
Solution
Many thanks,
Lee
