by Kez3 Contributor
4g symbol not appearing and no internet in France
Read more
Hello everyone,
I was traveling from the UK to Nigeria (transiting through Paris).
I have a £10 pack with 2GB.
My 4g worked  when I was in the UK, but when I landed in Paris and tried to switch on my 4G, the symbol would not appear and I would not have any internet.
Nonetheless, I could make calls without any trouble.
I’m traveling back soon, but was wondering if someone could help me explain the source of the problem.
Thanks again for your help
Ps: I checked on MyEE and I still have data allowance on my sim.
Solution
Re: 4g symbol not appearing and no internet in France
Thanks for coming back to me @Kez3
As long as you have purchased a suitable package this service should work, if not you would be prompted to purchase.
Please try a manual network selection and let me know the outcome.
Katie 🙂
15 REPLIES 15
@Kez3  Your using a roaming network when not in the UK so the signal and information that shows on your device comes from that roaming network.  EE is not responsible for that network or what your device shows when connected to that roaming network.
Do you not even get a 'E', '3G', 'H' or 'H+' symbol? Can't you use data on that? You can, you know.
by Kez3 Contributor
Hello Chris,
But I received a message from EE saying the following:
Welcome to France. Great news, if you have a pack, Free Boost or add-on, you can now use your allowances in France at no extra cost.
So shoudn’t it work anyways ?
Thanks again,
by Kez3 Contributor
Hello X-ray,
No, I didn’t get any symbol at all.
I was on the Orange network while in Paris.
As I said, I could call, but no internet or symbol when I switched it on.
thanks
Yes, it should work & can't see any reason why it doesn't, but as I pointed out earlier you don't need to see only a '4G' symbol to be able to use data.
by Kez3 Contributor
Do you think it was a bug on the orange network ?
You haven't set your phone's Network Mode under something like Mobile Networks to '4G' or 'LTE' Only by any chance?
by Kez3 Contributor
No, I haven’t.
Because when I was in Nigeria I had 3G on my local SIM card
Do you think my 4g was blocked or something ?
Regards
No, even if it was you'd still get 3G or 2G.
by Kez3 Contributor
I meant block data in general.
Not only 4g.
I would’ve probably gotten some information about it ?
Good Morning @Kez3.
Are you able to receive calls?
Have you tried a manual network selection?
Speak soon, Katie 🙂
by Kez3 Contributor
Hello Katie,
Yes I can receive calls, it’s just that my data wouldn’t work (with neither 4g, 2g, or any symbol appearing when I switched on data on my iPhone 5s).
I haven’t tried the manual network selection option.
I will do so when I travel back.
So I was thinking either there was maybe a bug on the orange network, or my data was restricted for some reason (maybe because I don’t have sufficient founds on my balance).
Nontheless, that shouldn’t be a problem because I have a pack, and I checked on myEE, I still have 2GB available.
Do you have any idea ?
Kind regards,
Solution
Katie 🙂
by Kez3 Contributor
Hello Katie,
Just a message to to say thank you.
My 4g is working now.
Regards,
Great news @Kez3
Hope you have a brilliant time in France 🙂
Come back to the community anytime!
