by Fozzy2670 Established Contributor
4g roaming speeds
Just had 10 days in Spain with crap 4g speeds and read article today saying EE have deliberately slowed down roaming speeds outside UK !!!! Is this true?
11 REPLIES 11
Re: 4g roaming speeds
Hi @Fozzy2670
What tariff are you on?
Thanks,
12 months 4gee sim
@Fozzy2670 wrote:
12 months 4gee sim
Max plan, Essential? Sim only? Legacy plan?
by Ace Contributor
Yes, it's true. EE have now said the speed limit will be lifted.
You may still get slow speeds, but it shouldn't be an artificial limit imposed by EE.
They’re a bunch of con men I rang about speeds they never mentioned this tried to blame handset
They will just find another way to stitch up customers I’m gone once contracts up
See attached speed test in Tenerife crap speed 4E4B6C95-3C7C-46BE-9CF0-5B9B4E8B3BC2.png
by Ace Contributor
@Fozzy2670 Whilst we wait for the image to be approved, maybe you can tell us the speeds?
Download 11.8
uupload 4.78
When is EE going to lift their cap on eu roaming speeds ? Also whose going to check that they don’t just raise the cap and try and get away with treating customers so badly again?
by Brilliant Contributor
Hello @Fozzy2670
Thank you for taking the time to post today. Smiley Happy
I noticed in your picture you uploaded, you're connected to WiFi and you're also on "EE WiFiCall". Did you preform the speed test on data or WiFi and are you connected to a VPN as WiFi Calling shouldn't be available while roaming abroad?
