by Leeleeliskeard
4g max plan
Hi
does this plan include roaming and calls in Australia.
cheers
Solution
Re: 4g max plan
Yes and 4 other non UK countries .
Solution
Re: 4g max plan
by Leeleeliskeard
Re: 4g max plan
Thanks, does it specify which non Uk countries? Or doesn’t it matter?
Cheers
Re: 4g max plan
The current Max plans allow you to use your UK allowances incl. 15 GB/month data if you have more in the EU + USA, Canada, Mexico, Oz & NZ.
Re: 4g max plan
Good Morning @Leeleeliskeard.
The 4G Max Plan includes calls, texts and data in Europe, as well as Australia, New Zealand, USA, Canada and Mexico 🙂
Jon
Re: 4g max plan
Looks like you just beat me to it @XRaySpeX!
