by Costacy Investigator
4g abroad
Hi.
I have roaming on but no 4g abroad.
Please help.
7 REPLIES 7
by Ace Contributor
Re: 4g abroad
Hi @Costacy
Can you try and enable it on your account?
If you log into MyEE and go to Manage device, make sure you have activated roaming and international calls.
Or If you have the MyEE app, go to usage controls, activate use phone abroad and make international and premium calls
If that doesn't work, let us know and we'll see what else we can do.
Re: 4g abroad
Hi ,
It is all enabled and also on my network settings.
I've tried everything and for some reason no 4g on this holiday!!!
Please help
by Ace Contributor
Re: 4g abroad
Hi @Costacy  Have you tried a reboot and a manual network search? What happens when you try and connect to a network?
Re: 4g abroad
Yes I have tried rebooting many times.
I also tried manually choosing a network but it didnt find one it kept looking
Re: 4g abroad
Hello @Costacy
Welcome to the community 🙂
Can you make calls and send texts?
What country are you in?
Speak soon.
Leanne
Re: 4g abroad
Hi Leanne.
Yes I can make calls and get edge I just can get 4g..
My work phone works perfectly.
Please help
Re: 4g abroad
Hi @Costacy
Thanks for coming back to me.
Where are you at the moment?
What device are you using?
Leanne 🙂
