by jfield123
4g Cyprus
I have a S8 on a 4G MAX plan. In Cyprus I roamed automatically onto Cytamobile-vodafone. I'm only connecting to H+, no 4G. I get up to 11 Mbps on speedtests which is not disastrous, but not quite what I expected. Cyprus is listed as 4G on the EE roaming list - should I expect this?
Solution
Re: 4g Cyprus
@jfield123  It’s going to depend on if that roaming network provides 4G in that area.
Have you tried manually selecting a different network to see if you can select a 4G network.
Solution
Re: 4g Cyprus
by jfield123
Re: 4g Cyprus
Thanks, I manually switched to MTN and it worked. I've seen posts here complaining about them but it seems fine.
Re: 4g Cyprus
Good Morning @jfield123.
I'm glad @Chris_B's brilliant advice helped you out 🙂
Feel free to come back to the community any time.
I hope you enjoy your time in Cyprus!
Jon
