by YellowBird
4GEE plan Data Roaming charges
I'm on the 4GEE 5gb plan, will I be charged extra for data roaming in Spain (Canaries)?
Solution
Re: 4GEE plan Data Roaming charges
@YellowBird: No, you may use your UK allowances whilst roaming Spain.
Solution
Hi @YellowBird
Welcome to the community. 🙂
@XRaySpeX is correct, you can use your normal UK allowances in Spain. 🙂
Make sure you text ROAMING to 150 to make sure your phone is set up before travelling.
Find out more information about using your allowances abroad >
Have a brilliant time. 😄
