by Chris Established Contributor
4GEE Max - Before May 10th
Hello All,
Im after a bit of help...
I have a 4GEE max plan which was taken out 22Sep 2016. I've seen in one of the posts that if it was taken out after May 'you can use your minutes, texts and data in 53 destinations including Canada, Mexico, Australia, New Zealand and USA.
Why does this not include plans before May? I now have a 4GEE plan that i dont get any benefit out of? Or am i incorrect with the above statement?
EE Employee
Solution
Re: 4GEE Max - Before May 10th
Hi @Chris and welcome to the community.
Please do give our customer services a quick call and they will be happy to place you on one of the new max plans.
It does not affect the current terms or your contract, it will though be an increase in cost depending on plan.
Many thanks,
Lee
24 REPLIES 24
by Brilliant Contributor
Please read the following COMMUNITY POST
This explains about people on the Max plan BEFORE 10 May.
Thanks for that, Completley missed that bit.
Dont suppose you know if this means a new contract to agree on the new 4GEE changes?
Think it's just a matter of moving you to the new tariff. But I would check with the advisor before agreeing to it all.
EE Employee
Solution
Many thanks,
Lee
by Ace Contributor
Slight Increase?
I pay £15 for 20GB now, and I can move for a 'slight increase' to £41 for 30GB as there's no 20GB plan.
EE Employee
Hi @chistery
I have edited my comment now to mention that the price increase depending on plan.
Many thanks,
Lee
Thanks @Lee_H. I’ve sorted this over the phone with EE :-).
Is there a easy way to tell if the plan has been updated to include the new 5 countries? I was told it can take upto 24 hours.
thanks
by Ace Contributor
In MyEE, your plan destription should update to:
"You get our very best with your 4GEE Max Plan: unlimited calls, text and xGB of our fastest speed data to use in the UK, and when you're abroad in the EU and selected countries. You can also get live sporting action on your phone with the BT sport app"
Make sure you also have roaming enabled before you leave.
by broadbandcat Established Contributor
Hi..same for me. Took mine out in March. Partial refund due EE ?? Customers on these plans are paying for what you now give for free..
Hi @broadbandcat,
Your current Max plan won't change in price, but you do have the option to switch to one of the new Max plans if you prefer.
If you would like to switch, please get in touch with customer services.
Thanks @chistery i noticed the 'selected countries' bit but wasnt sure. Perfect timing as i have a trip to America soon. Thanks again
by slliw Contributor
hmmm, I was upgraded to the new max plan yesterday but mine reads as follows
You get our very best with your 4GEE Max SIM Plan: unlimited calls, text and XXGB of our fastest speed data to use in the UK, EU and ten other countries. You also get live sporting action on your phone with the BT Sport app.
I have it confirmed from a different advisor that the 5 additional countries are now on my account
EE Employee
Hi @slliw and welcome to the community.
I will certainly look into this description for you.
Many thanks,
Lee
by Rosperc Investigator
Hi I am already in the US and stuck without data - can I change plan from US?
EE Employee
Hi @Rosperc
So I can try and assist, please may I know if you are using a personal or business account?
Many thanks,
Lee
Personal account
Many thanks
Jenny
[MOD EDIT: Please do not post personal details onto a public forum]
by Ace Contributor
@Rosperc Please edit your post and remove your phone number, this is a public forum.
Have you looked at the EE Travel Data pass? 500MB of data a day for £4. You need to text travel to 150 to add it though, so assume roaming does work just no add on enabled?
https://shop.ee.co.uk/international/travelling-abroad/travel-data-pass
EE Employee
Hi @Rosperc
Please pop to the live chat link.
This can be found in your Private Messages.
Our customer service team will be able to assist with your issue.
The link will be active from now till 8pm (UK TIME).
Let me know how you get on.
Many thanks,
Lee
Roaming enabled and when I text travel to 150 it says it's unavailable otherwise that is exactly what I would do!
