by Brettstabler
New Member
4GEE MAX plan Canada
Can't use my 4GEE MAX data in Canada? EE assured me it would work but I'm being asked to buy data add-ons.
by Ace Contributor
Re: 4GEE MAX plan Canada
Are you on a new max plan, that started after 10th May or the old Max plan? Did you upgrade to the max plan recently?
by Ace Contributor
@Brettstabler
When did you start your Max Plan ? EE have two Max Plan one before 10th May that only cover Europe But if you upgrade or change your price plan on or after 10th May that includes 5 more countries including Canada.
Many Thanks
EE Employee
Hi @Brettstabler and welcome to the community.
So I can try and assist, please may we know when you purchased your max plan as it does need to have been purchased after the 10th of May to include canada.
Many thanks
Lee
