by Pedlow39 Investigator
4G EE max box not working in states, red flashing light above 4G, working in UK
14 REPLIES 14
Re: 4G EE max box not working in states, red flashing light above 4G, working in
Did you activate roaming before you left?
No, never activated anything, possibly do activate roaming while abroad ??
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Checked my settings in manage devices, data roaming is enabled 🤔
Data roaming? I'm talking about roaming in general on your a/c.
by Ace Contributor
What box have you got @Pedlow39?
EE 4G max mini wifi box pay monthly account, sorry the I meant the roaming abroad that was activated
by Ace Contributor
Yea I think so, MIFI box mini, so the SIM card in my device will work in the US but the device does not by the sounds of it, that's excellent 🙂
by Profile closed
Not applicable
@chistery wrote:
@Pedlow39 same as this one?
https://community.ee.co.uk/t5/4G-and-mobile-data/MIFI-BOX-NOT-Working-in-USA/m-p/578348#M116129
Indeed, The EE branded WiFi and WiFi mini devices don't have the correct bands for both 4G or even 3G to work/roam in the USA unfortunately.
They only support 4G/LTE bands 3, 7 and 20 along with 3G/UMTS bands 1, 3 and 8.  None of which are used in the USA much sorry.
Thanks for the help, very frustrating, was sold this a month ago purely for using in the US and Canada as I will be spending quite a bit of time there and the next few months, agent knew this but obviously does not know his products 👍🏻
by Ace Contributor
Seems wrong to be selling a device and advertising it as being able to be used in the USA if it can't be doesn't it!
If you have a dual SIM phone you could use that and tether from it, or maybe see if Best buy sell unlocked devices that it'll work in?
Not seems, it is wrong lol look forward to visiting my friendly EE agent when I return to the UK 🙂
by Ace Contributor
Good luck with that. Let us know what happens! Robot Very Happy
Anyway, Enjoy the USA and Canada! Can't wait till I'm back in NYC in a few months time.
