by courteneystonex
Sony Xperia Xa it's charging and haven't got insurance can I get it fixed
by Ace Contributor
Re: Sony Xperia Xa it's charging and haven't got insurance can I get it fixed
Yes it can be fixed but at a cost.
Brendon (Android Expert)
Samsung Galaxy S8+ (Oreo 8.0)
by Legend
Legend
  • Try another cable and charging outlet (USB plug, USB port, socket)
  • If that fails contact Sony mobile support as they may repair under warranty
  • If not then try a third party repair or take the phone into EE to send off and obtain a repair quote.
Hi @courteneystonex
Welcome to the community.
We have a technical support team on hand to try and get the device working fully.
If they find it faulty, they'll run through the options for you.
Chris Smiley Happy
