by Welchy99 Investigator
How much is to fix anHow much is it to fix a Samsung galaxy A 5 broken screen
Solution
Re: How much is to fix anHow much is it to fix a Samsung galaxy A 5 broken scre
@Welchy99   You need to take it to a EE store so the device can be sent off for repair and assessed as all of the damage has to be repaired also.  Cost will depend on how much has to be fixed.
You’ll be told the cost before any repair work is carried out.
Solution
