by steve45 Investigator
Requesting a PAC code
I have just tried to request my PAC number and unfortunately failed the security question by incorrectly stating that my last top up amount (actioned months ago) was £40 instead of £20. The call taker simply said I had failed the security question and refused to let me have the PAC code. How long do I have to wait before I can try again?
by Brilliant Contributor
Solution
Re: Requesting a PAC code
You need to go into a store to unlock the account. There isnt a time limit.
If I have helped please click the STAR/SOLUTION buttons below
Solution
Thanks BrendonH. No store near me but I'm sure I'll have the correct answer for them next time. Just need to know how long to wait until I contact them again.
by Ace Contributor
Hi @steve45 if you have locked your account due to failed security you will need to visit a EE store with photographic ID so they can verify it's you and unlock your account so a PAC code can be genarated.
Like I stated there is no time limit
You have to visit a store.
Gotcha - thanks Brendan
