by Coz21 Established Contributor
Porting number
I have a micro everything pack PAYG sim in my phone. I want to use my son's old phone which has a nano data pack sim. Can I port my number to his sim even though it's a data pack? Can I do this by phoning CS? How long will it take for the number to port?
by Legend
Legend
Re: Porting number
Hi @Coz21
If you go into any EE store they can just provide you with the correct SIM and transfer your account across. Or call 150 and they can do the same, albeit they will charge you.
Re: Porting number
Thanks. I was goong to go into an EE store to get a new nano data pack sim, which is what I want. But then I thought as there is alreay a nano data pack sim in the phone that I'm about to start using, wouldn't it be easier to just get my number ported to that rather than getting a new sim?
Re: Porting number
Hi @Coz21
It's definitely easier to get a replacement SIM.
You can find your nearest EE store on our store finder.
Re: Porting number
@Coz21: By just getting a replacement SIM for yourself you won't get the benefit of the existing data pack your son has.
Is your son's SIM on contract or PAYG?
Port your no to another network's PAYG & then back to your son's SIM.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
Re: Porting number
Thanks, I will do that.
Re: Porting number
Thanks... it's payg. I'm not bothered about losing the benefits. I think I will just get a new sim.
Re: Porting number
Thanks! You're welcome Smiley Happy! Glad I could be of assistance.
If you are not bothered about the data pack, it's best to get a replacement SIM for yourself. Make sure you ask for a replacement SIM not just any old SIM.
Re: Porting number
I do want to change from an Everything pack to a data pack, but I mean I'm not bothered about losing what is already on the other data pack sim.
What do you mean by asking for a replacement sim? Do I not just ask for a payg data sim and ask for my number to be ported to it?
Re: Porting number
That's what a replacement SIM is; one with same number and credit  It is not ported but programmed in the shop. You can switch to a data pack yourself by texting DATA to 150 and choosing..
Re: Porting number
Thanks. I tried at one point to change to a data pack but it said it was unavailable with my sim. Anyway, I need a nano sim. Mine is a micro sim, so I will get a new one.
Re: Porting number
Don't you get anything offered when you text DATA to 150? You should do.
What about http://add-on.ee.co.uk/purchase when not connected to WiFi? What does that offer you?
Re: Porting number
Just text it and yes I do. Might try changing again. But no point now if I need a nano sim.
Re: Porting number
There is a point. When you get a replacement nano SIM your current pack will carry forward to it as will your no. & credit. That's what a replacement SIM is.
Re: Porting number
So even if I get the replacement sim now instead of waiting until it's time to top up again, everything will get carried over to the replacement sim?
Re: Porting number
yes
